Most teams don’t have a “downtime tool” problem; they have an alert trust problem.
When planned maintenance generates the same red alerts as real incidents, your monitoring becomes background noise. People start dismissing notifications, and that’s exactly when an actual outage sneaks through unnoticed.
This guide shows how to use scheduled and recurring downtime in Nagios XI to reduce downtime impact, minimize alert fatigue, and keep your team focused on what matters. If you’d prefer to follow along step-by-step, you can also reference our webinar recording walkthrough.
Scheduled vs. unscheduled downtime (the distinction that drives everything)
- Scheduled downtime: planned maintenance – patching, upgrades, hardware work, controlled reboots.
- Unscheduled downtime: unexpected outages – failures, misconfigurations, capacity issues, bad changes.
The goal isn’t to “hide” downtime. It’s to make sure your monitoring treats expected interruption differently from unexpected failure so alerts stay meaningful.
Documentation:
How To Configure Downtime In Nagios XI 2024 and 2026
Notification fatigue: the problem you don’t notice until it’s expensive
A loud burst of alerts from a single dependency dropping (think: a switch or upstream device) is easy to spot and fix, especially when your topology and relationships are modeled correctly.
Notification fatigue is quieter. It shows up when:
- certain alerts are “always noisy during patch night,” so people ignore them,
- sensitive thresholds create constant warnings that stop feeling urgent,
- planned maintenance produces repeated CRITICAL notifications that train everyone to tune out.
Downtime planning is a direct countermeasure: if you already know a host/service will be unavailable, tell Nagios XI in advance so your alert stream stays high-signal.
Nagios XI terminology that trips people up
Nagios XI supports scheduling downtime for a service, host, hostgroup, or servicegroup.
But in the UI, there are two places that matter:
1) Scheduled Downtime
Use this for one-off maintenance, like:
- emergency patching outside your normal cadence,
- an after-hours upgrade,
- a quick reboot window.
This is explicitly about preventing unnecessary notifications during an expected interruption.
2) Recurring Downtime
Use this for maintenance that happens on a regular schedule (weekly/monthly patch windows, routine reboot cycles, etc.).
If you ever need to troubleshoot recurring behavior, it helps to know the schedules are written to /usr/local/nagios/etc/recurringdowntime.cfg on the XI server.
Documentation:
Nagios XI – Recurring Downtime System
The practical workflow: plan it, run it, return to full sensitivity
Before maintenance: scope downtime correctly
Pick the tightest scope that matches the work:
- Host downtime for a single server/device.
- Service downtime for a specific component.
- Hostgroup/servicegroup downtime for fleet-style work.
Add a clear comment (e.g., “Monthly patching window”) so anyone looking at the timeline understands what’s happening.
During maintenance: keep the team informed
If you forgot to schedule downtime and alerts are firing:
- Acknowledge the problem with a note like “Maintenance in progress,” then
- schedule downtime so the rest of the expected noise doesn’t drown the dashboard.
After maintenance: end downtime early (highly recommended)
If your maintenance finishes in 25 minutes but you scheduled a 2-hour window, leaving downtime running suppresses the most valuable time to detect issues—right after changes.
Ending downtime early restores full monitoring sensitivity, so if something “looked fine” after patching but fails shortly after, you’ll actually see it.
Scaling up: use bulk downtime tools when maintenance hits many systems
For larger environments, doing downtime one object at a time is a great way to waste an afternoon.
Nagios XI includes bulk tools like:
- Mass Downtime (schedule or remove downtime across monitored objects).
- Mass Immediate Check (run immediate checks on problem-state objects).
- Mass Toggle Notifications (quick enable/disable notifications).
This is the fastest way to manage downtime at scale without scripting.
Related reading:
Nagios XI’s Bulk Object and Incident Management Options
Automate downtime with the Nagios XI REST API (ideal for patch automation)
If your patching is automated (Ansible, scripts, pipelines), downtime should be automated too.
Nagios XI’s REST API supports viewing, creating, and deleting downtime programmatically.
Example endpoints (placeholders shown):
# View current downtime
curl -XGET "http://<XI_IP>/nagiosxi/api/v1/objects/downtime?apikey=<API_KEY>&pretty=1"
# Schedule downtime
curl -XPOST "http://<XI_IP>/nagiosxi/api/v1/system/scheduleddowntime?apikey=<API_KEY>&pretty=1" \
-d "comment=Maintenance window&start=<unix_ts>&end=<unix_ts>&hosts[]=server1"
# Remove downtime
curl -XDELETE "http://<XI_IP>/nagiosxi/api/v1/system/scheduleddowntime/<internal_id>?apikey=<API_KEY>&pretty=1"That pattern maps cleanly to real maintenance:
- schedule downtime → 2) run updates → 3) remove downtime early → 4) optionally trigger immediate checks.
Bonus: downtime planning improves reporting accuracy
If you’re using XI reports for availability/health summaries, there’s an option to hide scheduled downtime so planned interruptions don’t distort what you’re trying to measure.
Try it with a 30-day Nagios XI trial
If you want to validate this workflow in a test environment, start a 30-day Nagios XI trial and run a patch cycle using scheduled/recurring downtime plus early removal. It’s a simple way to prove the process works before rolling it out.
Prefer a guided walkthrough? You can also request a demo to see how this would look in your environment and ask questions as you go.
